Ownership Experience
Wait. What? Where did you get that?
It’s plain number plates, you will get it in automobile spare parts shop.
the quality is as per specification (1mm thick aluminium plate). Since it doesn’t have any support, it bends. Order number plate frames online from Orbiz or Movell and put it. it won’t bend with the frame
Caution: You may have to struggle to put this because generally the back part of the frame is fixed first and then the plate is placed in it and then the front part of the frame is locked in place. but since HSRP has been fixed already so fixing the back portion of the frame might not be as easy
But we can’t remove front plate know, as they have used revit
But but but we can’t even remove the number plate right? How are you supposed to fix it?
Neatly cut the rear of the holder to fit the plate holder arm on the bike. Slide it and snap it on.
BUT, easy for me to give you Gyan :wink:
Genius idea saaar. I’ll order it and try it right away. Thank you for your suggestion.
Yes that’s why wrote that it might be tough. As @raghav.srinivasan has written a small slit/cut near the holder will be necessary. The frame itself need not be screwed or fixed. Because of the snap locks in the frames, both the parts will hold together firmly
Ordered it. Fingers crossed. Let this work. I’m tired of the number plate bending.
Reached a predicted range of 90km. So happy… good going Ather…
@Raghunandan good going… congrats
In Kaggadasapura 13th cross, last two days morning 7AM one gentlemen riding Ather, anyone here?
Bro what have you done. Orbiz number plate are not good at all. See in few days the paint will be vanished. You are wasting your money. And there customer support is worst.
Didn’t order plate Maga. Just ordered the frame.
Ok bro.
If some is planning to buy HSR plate. don’t buy HSR plate in orbiz.com.
(Worst plate I have ever seen)
I guess you were unlucky or probably it was the font style you’ve chosen.
The Orbiz plates that I have have been doing good so far.
OR
Probably I’m lucky or should wait for some more time
The problem is, currently there are very few vendors who give green embossed plates.
Sir,
There is nothing to do with font and only problem with paint they are using.
I have use 10rs oil paint. Now it is good.
Looks so good with that 10 RS. Oil paint…
Got it buddy…
Close enough???
Why dont we go bigger next time. A wider shot with lots more ather
