shailu8167
(Shailesh shenoy)
September 4, 2023, 10:36am
1
Cant do 100% charge at Dot charger ( home charger ) why so?? After Update
Novin
(Davis )
September 4, 2023, 10:37am
2
After update it will charge till 100% after midnight it’s called optimised charging 2.0
deandhruv
(Dhruv M)
September 4, 2023, 10:59am
3
Only if you keep it for charging between 6 pm to 1 am. It can however be disabled
Optimised Charging 2.0 will be available to all owners Gen 2 and above, and will be rolled out as an OTA update in phases.
The Optimised Charging feature enhances battery life and provides convenience by ensuring the scooter is fully charged by 5:00 AM in the morning.
After the update, this feature will be triggered if charging sessions start between 6:00 PM to 1:00 AM. The scooter will reach 100% SOC by the next morning at 5 AM.
You will have the option to enable/disable this feature for the current charging session on the charger-detected screen. You can visit settings on HMI, and use the “Optimised Charging” button to set the default ON or OFF state of the feature.
I plugged in my charger (portable) at 11:30PM last night. It started by showing estimated time of 03:45AM for 80% charge. It actually reached 80% at 05:00AM. And now it is showing estimated time till 100% as 07:30AM.
8 hours for a full charge is a huge duration! I’ve never seen the Ather take more than 5-6 hours for charging. Is there any way to find out what is causing this issue?
Novin
(Davis )
September 6, 2023, 12:56am
6
Disable optimised charging
Actually I just checked, I’m still on 5.7 version
Novin
(Davis )
September 6, 2023, 3:00am
8
Might be a glitch. See if it happens again
It might just be that the power went off in-between. Are you sure that didn’t happen?
Disable optimised charging form menu
