Last week I went for 55 kms but I got only 62 kms nearly
Then you need to check your riding pattern. If you give fast throttle then power goes more. Then range drops.
Itβs either a riding habit problem or ur vehicle problem.
If you recently started facing this issue, then its most probably a vehicle issue. And it could be an issue with the brakes. Try to spin the tyre with the motor off and see if there is any resistance.
Or ride for a few kilometres and see if your brake disks are hot.
How come you are having such poor efficiency of 51kmph? You are doing something wrong
There is a new blog post available on setting up your own bot for getting ride alerts; hope it will be useful to the community.
The new ride alert types
Ride statistics with no personal information, which can be easily forwarded to others.
Location information
Sample ride path with speed: a big hyperlink
