As per the “National Building Code of India 2016” by BIS, a load-bearing wall can be drilled to a depth of a third of its thickness if vertical and can be drilled to a depth of a sixth of its thickness if horizontal.
All Ather Home and Public charging locations comply with this regulation and in case we find walls or columns thinner than required, we use a floor-mounted mount for it.
You can refer to section 6.5 in the ‘National Building Code of India V1’ for the same regulation.
Please refer to the page 720 on the following link.
