I got most efficient ride of 69.6km/kw
I checked my Ather Rizta 3.7 kW most efficient ride is 69.6 kW so by calculation I got this range 69.6×3.7 kW = 257.52 km range in a single charge?
Ather installed 2 batteries of 3.7kwh in your vehicle by mistake. :face_with_hand_over_mouth:
Can’t Blame or Make Fun of Everything
You have to drive atleast 10 KMs to get actual Predicted Range, driving less KMs like 2-3 KMs at 10-20 KPH will show such a Prediction
Only 3.24 kwh is useable out of 3.7kwh so don’t calculate with 3.7kwh.
Baki ka fir ka kya hota hai ?
umm, the entire calculation is wrong, you have a 3700 Wh battery, in which you got 69.6 Wh per Km in efficiency so that it would be 3700/69.6 = 53.16km
He says 69.6km/kw not 69.6wh/km. His calculation is correct.
The data isn’t correct as like below.
Wait a min, when did they switch to km/unit from wh/km. Well actually this is more useful, and easy to understand.
I always waned to Cross 190+ range in single charge I believe my back would give up before that :ogre:
Baki battery reserve me rehti hai jese ki screen or lights ko on rakhne k liye or battery deep discharge se bchane k liye.
You need to drive 10-11 Hrs Straight Without Break and Speed must be at 20-25 KPH
Even 8 hr is crazy let alone 10-11 hr Literally means
:relieved_face:
Until You ride 10+ KMs, Predicted Range is just Big Numbers which are not Practical
And am sure ppl dint even realise they have achieved this all thanks to the app that we realise we have done that
Ather 450X HR 100% to 0%
What was the total range covered in single charge 205 kms was it @chef.arun7 ?
Yes. It’s easy to compare to all the generation vehicles.
The only concern is the app displays the most efficient ride, top speed. It’s no use to the customer, as these numbers are outliers. My most efficient ride is 95km/unit, top speed is 90+kmph, which I have never done. It was a test from service centre.
Assume a person selling his vehicle to other person, what the other person would expect?
It’s the average efficiency or range, SOH, battery imbalance, service history, etc., None of these details are fully available in the app.
It’s common when someone switches from ICE to EV, most of the doubts would be around range, battery. Everything else comes next.
Haha Not me, No Patience these Days
Where did you see this? I don’t see any Post of Forum ??
So finally they listened :clap:
