Red light comes on when the voltage between Neutral and Earth goes above the threshold. This is due to improper grounding/earthing.
If the unit was working fine earlier and showing differently now, it might be due to incoming power from the grid. Just watch out and it may be all right after a while.
If it continues still, you may ask an electrician to check
