Typically in such high rise apartments, the electricity meter will not be in the floor where the flat is located(14th floor in your case). The distance from your meter to your parking lot is more important than the floor on which your home is located.
I still have this issue the red light blinking when plugged in only appears the first time in a day when I charge. If I unplug and check again, it doesnāt appear / appears for a second and then turns green. Itās actually reducing as days go by. If it doesnāt resolve itself by the weekend Iāll call up customer care.
Hi Abhishek. Iām also buying the Ather, I just wanted to know if the home grid is smaller than public Ather grid.
Itās not smaller. same size.
Only thing is that home pod doesnāt come with a 5A/15A plug point that a public pod has.
no!
for looks it is exactly same
home charging point
public charging point
but main difference is with charging speeds
home charging pod is AC charger with charging time of 2.5 to 3 hours for full charge
public charging pod is DC charger with charging time 1hr to 80%
Thanks for the info.
How much time it takes for 80% charge with home charger?
around 2 hrs 15 min (more or less 15 min)
last 15-20% will take longer time - so i donāt bother to charge to full instead will stop at 80-85% even on my long trips i charge only around 90%
@Shreyas in home charging for 0 to 100 % how much units its consumes as i am not able to track pls help me out
2.4 units to be exact
Actually little more than that
While bike is charging, does the green light keep blinking?
Yes, The green light keeps blinkingā¦
Thanks for the confirmation
no problemā¦ enjoy your rideā¦
Yesterday I kept bike for charging, it showed full charge @3:45 am in the morning, when I saw @ 8 am, charge was still happening, is this fine or I should shut off the charger when fully charged? Will this harm the battery pack since charger was continuously on all night
No issues with leaving it plugged in. The BMS will take care of ensuring battery health.
Thanks for the info
ya I my case also same issue is happening. On the screen itās showing as 100% but still the green light is blinking on my Ather grid. And in my phone it is showing as charging.
Now I have started to switch off the power supply once charge is above 90 % as my daily commute is approx 50km.
