10rs per charge … monthly 300…if u charge on Ather fast charger from August 1 2013 …it will cost u around 1950 -2000 rs …they are charging 1rs for1km …
Technically not true, though does depend on what percentage of SoC you’re at and a few other factors as its based on time.
I am already using this scooter…i drive daily 130-150 km …I know it better
Same as everyone else here. Secondly, sit with a timer at a fast charger while charging 0-60% charges up a lot quicker than a km per min it’s the bottom end from 60-80% that takes more time. As well as you’re comparing the cost of charging with a fast charger to home charging that’s like comparing apples to oranges. Even with your case of driving 130kms per day you’d hardly need a top up of 15-20 mins after the charge from home charger gets depleted to complete your daily
Dumb question–how do I get access to this stat for my scooter? Stats for private charging as well as Ather grid?
Previously Ather used to send us monthly stats via email. Looks like it’s stopped now.
Any way to get this information now also? Anyone from Ather who can help with this?
It is simple calculation.i have Ather Rizta 159IDC.3.7 kw battery pack.after so many home charging experience my calculations are as below:
750 fast charger speed: 18% in 1 hour.
18% of 3.7kw(3700watt battery) is 666 watt battery percentage of Ather battery.(0.67 unit of electricity as well in 1 hr charging at home).
if I charge 3 hr/54% battery,I will charge 666*3=1998watt battery (2kw battery approx)& it will consume 2kwh electricity which is equal to 2 unit.![]()
Simple Solution.
I installed a smart plug that measures the units consumed. Tapo, Qubo, Philips, Wipro all have this for around ₹1k.
