Dot and portable charger are exactly the same wrt specs, better get a portable one. Only benefit of dot is that its convenient to put at home and charge. You can do the same with portable one, and also use it while away from home if needed.
Other benefits of dot…
And it can fit in the boot.
So the dot hangs on my wall at home? Or is it drilled into the wall?
Drilled into the wall
Just get an electric scooter with a better range… Save yourself the hassles everyday
Can be either. Can be wall mounted to hang, or drilled into the wall.
Thanks needed to know that , which means i can take it with me if needed.
