So are we! These cute little touches are lower on the priority list for now, but we’ll pass this feedback along to the industrial design team.
We will look into this, but can’t promise anything given the already limited real estate we have on the dashboard screens.
Based on user feedback, a lot of people did not use trip b too frequently - we will look into it
We have noticed that the new UI is resource heavy specially on our gen 2 hardware which has lower RAM - we are working on making a more improving it. We are not considering a move back to the old UI right now.
Although in most cases the lag should be minimal, but there are a few corner case scenarios which can cause the lag to build up - we are working on resolving this
We’ve received this feedback a few times. We’ll look into the feasibility of this with the current UI.
So can we expect regen revamp to be rolled out to gen2 users? Since current regen is practically unchanged from 450 gen1. And Can you please add Series 1 animation like it was in previous U.I it was nice little touch which I missing with latest Atherstack.
Thanks for sharing the feedback. We had started measuring the time lag for send to scooter but will relook at it to see if the pattern has changed recently, and work on the fix.
The data is used broadly for the following categories of use cases:
- Building data based products and features for the Ather owners. For e.g. Ride stats which is now evolving into RideStories with a lot of rich pattern analysis and insights data or predicting batter charge consumption for a particular ride in trip planner and to measure if a trip is feasible or not- both of these are highly used by many Ather owners and also we are the first in 2w industry globally.
- For R&D to design better specs for our vehicles. Example would be by measuring how often brakes are used helps our team define quality specs that can last over 10 years and so on. This is different from traditional automotive design where expertise and intuition would be used to define these specs. Those are still required but combining with data significantly improves the design process, specially where a lot of guesswork is involved.
- For predictive diagnostics and remote diagnostics- here again we have fairly advanced models and algorithms that makes our fleet much safer as we have the ability to predict issues and recall specific vehicles or diagnose issues remotely to send a fix via OTA.
These notifications wouldn’t not distract user while riding Ather? As per mentioned in previous question.
Answered the real time efficiency vs wings of power above. Please do check that one out.
Re: the second point, the effort vs customer benefit is not exactly proportional here. We do also want you to focus on the joy of the ride, and not burden your brain with pesky details like temperature while warping. Leave it to us to manage things like temperature fluctuations ![]()
Thanks for the kind words. We will continue to improve and optimise.
Just curious - any reason why you would want to be able to toggle it on/off situationally vs. just leaving it on permanently?
Not if we design the interface extremely well
@sripriya.nellore @ryan care to respond to this? It as 13 upvotes as of now.
This is something that we are looking into - we have identified a few causes for it and are actively working on it, you should start to see an improvement in your experience.
Can we expect upgrade option for 450+ to 450X for Extra mileage? Since we all know 450+ Is 450X.
That’s a good question! No, we designed the experience so that these notifications can only be read when the vehicle is stationary, like at a signal.
We made Ather Connect free around 2 years ago in order to mature the product, as well as bring it to a minimum cost structure. We have made good strides on both aspects though there is always more we can do. Ather Connect, like any product is not charged just because there is recurring cost; it is charged because it is of value. On that, agree with you that the experience needs to be good for the product to be useful. We also understand that most vehicles don’t have these features and thus, not all users have a need for these features. That’s why it is charged as an optional subscription.
On the other questions:
- WiFi is far more unstable than mobile network connection- the experience would take a massive hit and a ton of work needs to be done on it. Using WiFi as a fall-back would make more sense than replacing it with the more reliable 4G connectivity. There is a more detailed answer to this in another post that I would encourage you to go through. There are also certain restrictions on what we can or can’t use with maps. All the features available to consumers on the mobile app maps is not available to businesses. Open street maps means building our own maps- while it can always be explored, nobody beats Google today in terms of the data coverage that they have.
- Software updates are being provided. If your question is specific to Gen 1 450, most are on 2G which makes OTA nearly impossible. There was an option to upgrade to 3G, but most customers chose to go for a model upgrade itself which we offered. Even mobile companies are unable to support phones on 2G.
- App requires permissions strictly for the features that are implemented as defined by the platform- Android or iOS. We don’t ask for permissions for any other data if there isn’t a feature that needs it. Having said that, we are looking into feasibility of building a flow where permissions are asked only when a feature is being used (e.g. on bluetooth pairing).
- Feedback on bluetooth is noted and the teams have been working on it to continuously improve it. One difference to note between a Rs. 1000 smart band is that they connect to mobile devices which are certified. Our dashboard is on Android opensource and not certified by Google (as Google hasn’t designed Android for 2W)- so that makes it different from a tech implementation compared to pairing with a mobile phone. We have to build all the libraries ourselves that is otherwise offered by the mobile platforms.
Overall, we have our work cut out for us. These are good questions and I am glad you asked them.
How about enabling speakers for Google maps navigation audio, music playback, calls and voice assistant?
Giving 2G as a reason is not fair, if Ather really intends to send feature updates they can push OTA and people with 3G dongle can install using OTA and others will get it updated in service centers
