Atleast I can confirm this for me. Maps must have stopped/ blanked like 6-8 times during my drive from Mulund to Khandala (80kms). The weather was kinda hot and the dashboard was extremely warm. In the evening, I faced absolutely no issues with maps or dashboard when it was cooler. I drove from Khandala to Pune (60 kms). It was the most wonderful software experience ever. And yes, when the maps stopped/ blanked out, I could still use the dashboard.
Nothing was able to respond at that time noticed a pattern in which the touch seems to be non responsive as soon as maps blanks out in which manual restart is the only option
@abhishek.balaji When are you gonna release 10.1.5 for early beta testers ? My scooter isn’t syncing and my maps is also not working from last 13-14 days. I also cannot connect my iPhone to the scooter. Went to the EC, the issue was resolved. But the issues started again after leaving the EC.
17 posts were merged into an existing topic: 450X: Product/Technical discussions
Its been released already for the beta tester. If you have not got it , it means you are not beta tester yet.
When we can expect the iOS app update? It has been 6 months so far !
Why we don’t have same updates for both Android & iOS app?
The side stand sensor upgrade is a very useful feature and needed also. I was surprised at the beginning, why this feature was not there. Thank you for providing this feature now.
Sync is extremely unreliable. Have to constantly reboot it to sync. Ride statistics are not showing up. Unable to see vehicle charge status either.
update ather atomstack 10.1.4. What bugs are fixed in this version 10.1.4 update…
My ather got updated to atomstack 10.1.4 version can anyone know update contains… And what bugs it fixed
Series 1, AtherStack Atom version, keep restarting screen during ride. Not sure what’s the issue. Fan/Motor noise is too loud now.
Series 1 getting blank screen, while driving all of a sudden need to restart again and again to get going can you clear it out.
Hey Abhishek @abhishek.balaji I am using 450X S1 for a week now… I wish to suggest following updates in next Ver. if you guys find it correct & if its feasible.
- There should be PIN/ Password protection for going into settings from dashboard specially to toggle incognito mode and customer name, number & WIN no. These are private info and settings which should not be accessible to anyone using scooter other than the owner…
- There should be menu to lock / disable WARP mode (something like parental control for kids) in 450X
- When charging is completed there should be sound notification on mobile app.
- Non Connect pro subscriber should at least get current ride status with all details like efficiency etc on dashboard.
- The synch issues if they are related eSIM & Service provider’s network issues then a) owner should know which Service provider it is on & b) if that network provider have issues in the city/area then option to port to new service provider.
Love to see such updates in next OTA. Thanks
Does anyone else feel the under-seat vibration during warp mode even after fully releasing the throttle? and the vibrations stop after 5-8 seconds?
That would be your under-crotch fan in action.
I thought so, but it wasn’t that evident before the 10.1.5 early access Update. And I would stop after Throttle release unlike what I am feeling now.
It’s triggered by motor temp and / or RPM, and keeps running till the temp drops below the set point. It’s annoyingly rumbly too. Mine shuts off within a couple of seconds after a hard run. You might want to check if there’s some debris in the motor area that’s blocking some ventilation.
I felt slight vibration at footboard area.
This is not that slight…This feeling is as if you are sitting on a running tractor Bonnet(If you ever had a chance) The vibrations are too much.
Those fans are known to be defective like that.
Dashboard Fan going bonkers based on that timid dashboard’s temp make sense. But on rpm, it makes so sense. It is not been implemented very well. Forget the speed, the fan should kick in if the temperature rises. I have seen tht fan going crazy in a nice pleasant and cold weather. Its simply annoying. Only if Ather can hire real talent, we will see more logical developments.
