What are the IP Ratings of 450?
IP Stands for Ingress Protection
Battery: IP67 Dashboard: IP65 Motor: IP66 Motor Controller: IP65
Read more about IP ratings at
First Digit
6: No ingress of dust; complete protection against contact (dust tight). A vacuum must be applied. Test duration of up to 8 hours based on airflow.
Second Digit
5: Water projected by a nozzle (6.3 mm) against enclosure from any direction shall have no harmful effects.
6: Water projected in powerful jets (12.5 mm nozzle) against the enclosure from any direction shall have no harmful effects.
7: 1 m depth Ingress of water in harmful quantity shall not be possible when the enclosure is immersed in water under defined conditions of pressure and time (up to 1 m of submersion).
