Tyre pressure drop issue
How many face air pressure drop issue tubeless tyre
If you’re facing an air pressure drop in your Ather 450X tubeless tyre, it could be due to small punctures, a leaking valve, or rim issues. Try checking for visible damage, tightening the valve, or getting the tyre reseated at a shop
Since ur new to forum I assume it’s a fairly new vehicle u own and mostly rizta…
Check for mostly
  1. Small Punctures or Nail Damage
    Use a soapy water solution to detect leaks bubbles
    will form at the leak point
  2. Valve Stem Leak
    the valve should be properly tightened. If the valve
    core is faulty, replace it with a new one. A tyre shop
    can help with this. This might be a problem at ather
    service centre better do it outside then rather.
    auguring
    back and forth for 10-20 mnts.
It’s not common but u would be even more suprised at those who don’t even realise they are running low on air
You have 2 options one is to change Valve Stem or get TPMS installed because TPMS valves are of higher quality and there is zero air leakage with that, or get new tyre valve stems changed which in certain cases reduces air leakage
Thanks buddy
