The TPMS is working all fine and the notification pop up’s are also working good if the pressure goes uneven. I still didn’t check it in a bunk, will check this and update.
The problem is the pressure doesn’t stay exact numbers it keeps on going up and down 1 or 2 psi and sometimes if I take a pillion the pressure in the rear Tyre suddenly goes up.
I just pumped air to both the tyres to 30 and 32 psi( these numbers were indicated on the screen) today morning. From morning they are not constant they are going up and down. The tyre pressure is changing after the rides.
- Starting of the ride ( I made them 30 and 32 but
don’t know how they got increased. I also waited
for some time after making both of them 30 and 32psi, thought that it takes some time to load the numbers but they didn’t. After some hours
they were changed)
- After some time when a pillion sat back the rear tyre pressure increased to 37
- At the start of the ride:-
- End of the ride:-
From 3rd and 4th point I say that the pressure varies during the rides. Varying of pressure during rides is ok but variations while on idle is not ok, that is what I said in first point.
Other than this, deflated both the tyres less than 20 psi and I am immediately getting the notification on the app and also getting alerts in the dashboard.
