That’s some risky thing to do.
Stopped at 200 odo. Anyway i needed a reason to stop riding and start charging. I could attain near to max speed on locked eco mode for 5 times. 35 km/h is max on eco? And according to strava my max speed was 55 km/h. I have also accelerated 5 times to attain that speed. Definitely not a bad efficiency at all. But only if i continue close to this my range would improve.
The longer route was to pick up n drop pillion rider to the location where the GPS is on in the map. Later i played a bit.
Just before i connected the charger i switched off the vehicle. After 5 secs both front and tail lights blinked once along with dashboard on for 2 secs. Bug?
Nice! You rode for 9.6KMs consuming 12% battery
Haha yep definitely risky!
Wow with the average of 32 km/h good achievement.
Hi, I own a 450 plus. What maximum range does 450 plus provide? I guess it will vary from 450x. Can anyone share 450 plus stats?
In ather use importing batteries l think replacement battery cost is high… how much battery cost come can you tell me sir…
AFAIK, Ather makes their own batteries, and they are good for 6 years or so, on a moderate usage. Don’t think you have to worry about replacing them anytime soon.
And, you get 3 years warranty on the battery anyways. If your battery capacity goes less than 75% in 3 years, you get a free replacement. And they are expecting the battery costs to go down by 50% in 3 years. So shouldn’t be very expensive I hope.
Bro, my brand new 450x Series 1 - gave me a range of 70 km only from 100-0… I don’t know if it’s just one day old or hot day or because two riders with bags…
Hey Malank, welcome!
Is it a first time like this or is has it been with this range since you have it? What does the efficiency numbers show?
That sounds about right. Especially if you were riding with pillion and luggage. The range also matters on a lot of other factors. Most importantly your riding style. Did you ride in Eco mode only ?
Yup, I rode totally on eco mode from start to end… I guess you might be correct the range might have been less because I was riding with pillion and luggage… Will make observation while riding alone…
Hi, it’s been just few days since I bought this beauty, will observe for few more days… And let you know… !
For know this is what its showing…
Efficiency numbers are on the higher side. After initial tests, try the suggestions discussed on this thread.
Seems about right if you’re on full throttle at most times even in eco mode.
With pillion and luggage , that’s a pretty good number!
Today completed 93km total on single charge and reached home with 20% battery left on dashboard. I can confidently say that 115km can be cover easily on this beast.
Tips: I was riding between 25 to 45 speed with ECO, RIDE & WARP mode and specially leave the accelerator when u see from far the speed breaker. All flyovers no acceleration to decline and apply less brakes as it was early morning ride.
Even then these figures are amazing. Either you’re really weight less or you were riding on absolutely flat roads.
Mostly flat roads with many flyovers. My weight is 85+.
