Shift Ather Home Charger
I am shifting my house within Bangalore. What is the procedure for shifting the home charger to the new premises?
Are you using DOT? If yes, you can move the charger on your own. It is very simple to disassemble. If needed, you may employ any electrician too. However if you are using old version charger (POD), then it is bit tricky. Good to get it done through Ather Service Personnel. Call Customer Service or Log an issue through the app and schedule.
