can u please be more specific
like from where you are observing the sound
Motor, floor board, disk brakes …???
if it is from belt - i did observe sometimes - but it is not a concern i believe
My legs feels the rubbing.
thats resonance from drive train
it’s there on all
don’t worry it’s fine nothing bad with the vehicle
Ok sir thanks
Hello nayeem. I’m interested
Awesome am sure this will go above 100km
first time is saw you mobile charge is below 90%!!
Nice observation, cable was plugged to mobile but main switch was off. Anyway this wont happen when charging Ather.
Why Ather Customer Care number is not in service…080-39513589…is there a different number?
Wanted to know about address proof options…none of my documents is having karnataka address…and I don’t have my name in the rental agreement…Electricity bill also don’t have my name in it…what to do?
which network r u using
try from other network - it will connect - have experienced the same before - they are fixing it
also u can reach on 08046808088
This is really encouraging!!
you better not try it!!
This week mine swayed between 79km to 74km range.
Thanks Abhishek…the number you shared worked…
I am using BSNL.
Just wondering- The app shows “Fast Charging” when plugged in to my home pod. And after few mins it changes to “Charging”. What does it mean?
As I have known so far the fast charging is available only at grid points while home pod and the portable charger are the slower chargers (both same intensity as per ather). Is there a possibility that home pods can also fast charge but configured only for slow charging as of now for technical reasons?
Hey @kumaranchal,
There is absolutely no way for the home charging point/cable to fast charge.
This must be a glitch in the app. Will get it checked with the SW team.
Thanks for pointing this out!
I
My 450’s dash screen stuck!
Even after turning off the scooter, the dashboard is glowing.
The running distance and speed are not showing.
I have put the vehicle into charging. The glitch is not vanishing. The vehicle is performing the things. But with the stuck screen, it’s not feeling good. Tmrw morning I will contact the Ather’s helpline.
I called the road side assistance and got the help. The frozen screen was reset.
Sachin from Ather gave the details to reset the screen.
Simultaneously hold both brakes and press start button for 3 seconds.
First time I saw the Ather logo on screen during screen restart.
He informed that it’s a small bug and should not be recurring .
Only thing is ODO didn’t record the distance during the frozen screen.
I took the deliver on Friday evening. So far the experience has been good and it is quite an eye catcher. Almost every signal I stop I being asked about it. Free marketing !!! I have completed about 50 kms.
I have a question. After a few kms, I get a noise from the front, maybe dashboard. The sound is like a fan speed of a PC. it reduces when I about to stop and it is not there when the scooter is stopped. it starts again after probably a few mins or I cross abt 18 kmph.
Anyone observed the same ??? Or is it normal ???
I will call their call center tomorrow and check too !!
it is fan for your motor
completely normal
u won’t har it when you are doing above 25kmph
