I didn’t even know the mirror could be tilted up and down, i though only in and out are possible.
At this point i am not sure if my bike mirrors has problem or if it’s too tight.
I’ll update the status once checking the mirrors after couple of hours !
Mirror are something that’s bothering me as well
Had near misses so many times on outer ring road
With no options went for blind spot mirror which as increased the viewing angle more and i feel much safer now
I feel that regen plays a major role in the overall lifetime of the scooter with respect to it’s range and the battery. Since regenerative braking is an electronically controlled mechanism, it should offer more customisability to the users.
Some of the possible settings would be to have either strong regen or normal regen. Strong regen would be defined as the scooter regenerating as soon as you let go of the throttle without the need to twist the throttle in the opposite direction, while the latter could be similar to the setup we already have going.
Alongside this, an active regen indicator (maybe showing a green glow instead of the red glow when regenerating) would be a requirement as currently, the amount regenerated cannot be quantified and thus, we can’t exactly project how useful regen braking in the real world is.
Very True,
I am completely disappointed with the nil Regen in Ather presently !!
They should provide user to control the Regen settings in % like the Ultraviolette F77 controls.
With proper strong regen setting feature in future,
we can avoid most of the braking in traffic as have longer range on travel especially in roads full of traffic.
This is probably the reason stronger regen has bot been introduced yet, to judge the stopping distance using regen will be a learned art, it will lead to accidents i feel. At the end of the day, having an option to increase the regen percentage after knowing the risks would definitely be welcome.
Hey @Ather.Team. A small bit of information that is missing from our dashboard. Which can be updated as a monthly thing ( maybe through the usage report) or as a constant thing on the dashboard.
Revolt gets a SoH state of health of the battery. Seems to be really helpful to maintain good battery usage habits.
Do look into it since Revolt is able to do it, I wonder if its not doable by our own Ather.
