If you have a 16a socket use that, Don’t use the converter, the converter is just in place if the 16a socket is not available plus it removes the fear of loose contacts if a converter is used.
It’s completely safe as long as you use proper wire and socket
Connect the wire back to the centre pin, That wire is for Earth, If it’s hanging lose it might short with live wire and can become hazardous, PS the PRCD and Ather GND pins require an Earth connection.
you can use it as long as the prongs don’t become loose.
I am using a cona extension board and it’s been working without any problem. Sometimes i charge 2 Ather’s back to back using that extension board and it charges pretty well without any issues.
This is the gap between the PRCD plug and the 16A socket. I dont know why but no matter how much ever i push the plug it doesn’t go completely in it, leaves a gap in between. So is it safe to charge the scooter having this gap in between the plug and the socket?
Sorry for asking so many questions about charging the scooter. I have no idea how electricity works so thought that i will get some help in the forum.
What the Hell, it cannot have this much gap in between, try replacing the socket with known brands like Anchor Roma, GM, Legrand, or Havells. Most likely you will end up replacing the faceplate and the box but it will be worth it.
@kotteeswar25@newsolankisteels while charging for approx 1hr try removing the plug and touch it see how much heat it generates due to 5amps i faced this issue and immediately changed the switch to 16amps and it was solved
Technically it should not since the charger will consume 2.5A to 3A max (as per my observation). Should work on 5A without a problem. Is your charger directly plugged in to socket or is through extension? If through extension you can check the diameter of your wire, since this could also be an issue if the wire is not thick enough to carry the 5A current. Wire thickness >1.5sqmm is recommended for 5A.
I have faced the issue with 5Amper socket and plug and could even touch the plug after 30mins it was so hot so I got everything changed to 16 Amper and that solved the problem
