@Shreyas Me too just kidding:crazy_face:, when did u pre-order… Nd wats ur order no:face_with_hand_over_mouth:
Oh awesome. I was actually considering MT Mugello, but a smaller one. Guess it shouldn’t be a problem then.
Abishek
(H Abishek)
February 20, 2019, 3:22pm
472
I removed the Saree guard on the first day as I reached home after delivery … I believe it spoiled the whole clean look of the 450 . Its just 2 allen screws which will take 5mins to remove . Removing it wouldn’t cause any trouble with the cops .
Got rid off it just now … the bike looks cool now
Can @AtherTeam pls let us know by when order IDs in the 4000 series would start getting delivered as my order id is 4641 kindly update @Shreyas
upendra410
(Upendra Kumar Mallareddy)
February 21, 2019, 8:02am
475
@Abhishek what should be the ideal tyre pressure for the Ather flight (PSI)
Abhishek
(Flight 6947)
February 21, 2019, 8:10am
476
30 if u r not on the bike
if u r on the bike 32
pkg7723
(PKG)
February 21, 2019, 8:17am
477
pkg7723
(PKG)
February 21, 2019, 8:20am
479
Thanks bro. Soon its going to be my time to ride flight.
Abhishek
(Flight 6947)
February 21, 2019, 8:22am
480
yehhh…
Welcome to Flight _ _ _ _
i can see that enthusiasm already
upendra410
February 21, 2019, 8:26am
481
Both wheels, normally front should be lesser than than rear wheel.
Abhishek
(Flight 6947)
February 21, 2019, 8:29am
482
not necessary when wheels are the same
also note weight distribution is perfect on this
rkpuram71
(Rkpuram71)
February 21, 2019, 8:41am
484
I am getting my 450 on this Saturday.
My order id : 1688
Booked on : 6 th June
Pre order interest shown on April 2016.
Finally i am getting mine this weekend.
iamgyan
(Iamgyan)
February 21, 2019, 9:03am
486
Isn’t this mentioned anywhere on a sticker on the scoot? Normally all vehicles will have a sticker somewhere displaying recommended tyre pressure. Apart from this, this MUST be there in user manual too. Aren’t the owners going through it?
upendra410
February 21, 2019, 10:04am
488
Rajesh…how is regen works, it is simply applying the brakes right?
pkg7723
(PKG)
February 21, 2019, 10:06am
489
Can any one explain me the meaning of regen. What is it ?
rajeshkav
(Rajesh Kav)
February 21, 2019, 10:23am
490
Check these links for understanding ReGen
There are multiple ways to engage regen. Unlike engine braking, engaging regen is electronic and not mechanical.
While some manufacturers engage regen as soon as you let go of the throttle grip/accelerator, the Ather 450/340 do not engage it and start to coast freely.
Regen can be enabled by twisting the throttle grip or by applying brakes.
Using the kill switch while riding is not a good idea. Once the motor turns off, turning it on requires pressing brake and start after dis-engaging the kill-switch. Super risky a thing to do on the road.
The function can be modified via OTA.
As for the regen intensity, it too can be modified via OTA and we are working on it. Multiple reasons on why it’s at a low-intensity setting presently.
Yes. The throttle can be rotated in both +ve and -ve direction, it rests at a zero point if you let i…
