#Bringbackcoolingfan for apex
Previous generation had cooling system when motor (6.4kw gen 3) heats up
And apex have 7kw motor and it’s not able to give sustaintnd performance without cooling
As in 2025 model of 450x series have 6kw motor (new), previous had (6.4kw) this is to resist heat in motor with magic twist . As magic twist bring heat in motor and in apex this is too much for motor to withstand and it give heavy performance degradation I can feel the hot air comming out from the under seat of front panal. So if cooling is implemented to apex it need it than bms doing it or you should expose motor to direct cooling which is not possible .pls give provision to give external cooling fan
I had raised ticket on this I need to know other option on this
Apex owner pls respond
It is a 6.4kw motor. I dont know some of them are getting info that it is a 6kw. Check the specs sheet.
450Specsheet 2025
I have been talking about the Power loss in the Gen 4 above including Apex past 1 Yr. This link shows the Developer Mode of Apex 2024
They will not be ready to Implement the Fans Back due to their Adamant Attitude
We need fan back on gen 4 Ather 450 aswell
Even if they do, the vehicles that are sold are done. Nothing will be done for them.
They may add for new vehicles, if they wish.
They should call back old customers and install it :smiling_face_with_tear:
Go to the site atherenergy.com and see
Actually display fans are there I saw it working
Their site is wrong. I’ve always observed such petty mistakes on their website. They are not updating their site properly. There will be a lot of mistakes if you keenly observe on their site.:joy:
So yea it is still 6.4kw motor they are using. :smile:
Then if it still 6.4 motor with magic twist
Then sure autohold cuts off veryfast and motor will heat at longer ride or high speed Apex users know this issue now Welcome the 450x series to new heating issue and end up using normal disc brakes than the magic twist
And after motor getting heated magic twist get weaken weaken and at a situation it won’t even work
Get ready for that 450x user to experience it
i bought Ather just because it had fan, imagine my pain it goes upto 45 here in my city i have no idea what to do now
They refuse to acknowledge the shortcomings of their decisions. They cut corners with the Apex, launching it as the “pinnacle of the 450 Platform.” Yet, barely ten months later, the Apex is already outdated and lacks traction control. This is because Ather skimped on a wheel sensor during the Apex’s initial launch, even though traction control was already in the final stages of development.
Yeah What you said is True and Fact. They should atleast get the Fans Back in the Future Models.
Everyone do mistakes but We need to Correct them at Some Point. Living with Issue in ourselves and Giving Compromising Replies will not be Good for Both Parties :face_with_spiral_eyes::hand_with_index_finger_and_thumb_crossed:
Yep, We are raising voice for everyone :smiling_face:
That’s Possible but OEM have to think about it and Good Enough to Accept their Mistakes and Fix them
Sir Display fan is not a Thing Wheee are discussing about, That have no relationship with Performance also.
We are talking about Motor Cooling Fan 🪭
Ather Energy and their Website both are living 2 Light Years away. So We may see some Old Datas in the Website for Sometime. Ignore it like @dhruvante said
Ather Energy has replied thru call to @rakshithricky1994 to give rest for 5-10 Mins then Proceed with Warp+ on His Apex. We have Call Recording.
Ather has Absent Mentality like me i guess
if Ather doesn’t care about it’s users then we should stop caring about their reputation of being rnd focused reliable ev maker, they really want us to wait to be able to use it when it overheats instead of providing a fan
People know about me well, I was a Huge Supporter Ather
But They are not caring about Customers.
I am really frustrated about the COOLING FAN ISSUE :confused:
exactly, i was honestly impressed with ola s1 pro but the only reason I did not consider buying it was absence of fan and it’s batteries catching fire, Ather without fan will atleast break the motor or battery much before 8 years but seems like they’re r&d-ing legal ways to avoid replacing battery packs even saw someone here saying his battery warranty was rejected due to a small scratch on bottom of the battery pack (Ather themselves removed the panel below the battery pack )
I am not really ready to speak a Single Word about that Brand.
Yeah, I also heard from Two Service Centers. They are Also mentioned the Same
Maybe I request People to Stick Something Under the Battery which doesn’t interrupt the Battery Performance or Heating.
In this Battery Topic, I like Ultraviolette Automotives :sparkles:
this is a must imo, tit for tat for this scummy move of removing the protective panel then denying warranty
Is it got removed only on Rizta or Both Gens :face_with_spiral_eyes::pensive:
Both of them bro. It was removed with the new colour introduction in gen3 (or you say gen3.1)
