My first home charging experience… I plugged it in to Pod when it was 85%. It said that it was installing updates for 5 minutes (even though i was on the latest 4.0.4.* version), then began charging with estimated time for completion displayed at 1.30 hours. I checked on it after 3 hours, it was at 100%, but did not say charging has completed. It said that was still charging, while indicating 100%.
Unplugged, and replugged it from the vehicle, resumed charging at 100% percent. I don’t think this is right… Will check by charging again later to see if this continues to say charging at 100%
The auto cut off at 100% doesn’t look like is working for me. It says “charging” indefinitely in the app and dashboard… and the Dot keeps blinking green indicating that it is still charging. I have raised an issue through the app. I am not sure if there will be other detrimental effects if I leave it plugged in for several hours at 100% SoC.
Well, even though dashboard might show 100%, it might continue to trickle charge for several minutes. For sure there won’t be any adverse affect. You can continue charging and see that it will stop after a while. Not that charging is controlled by 450 and not by charger.
However if you are not using 100% charge distance (i mean to say 80-90Kms a day), I suggest you to stop charging at 80%. 80-20 rule is best to adapt for longevity.
Sure, will keep it in mind, although it is cumbersome to manually monitor it until it reaches 80% and then go to the vehicle to unplug it. Hope it can all be controlled in the app, in the near future.
Yes, it is the wish list to have app based cut off. However we need to do it manually now. What I do is, I will note down the time to reach 80% and set an alarm in my mobile.
Well, how should I answer? Hope you have read this post in FAQ.
In simple words, you can charge overnight without any issue as 450’s BMS takes care of everything for an easy going person. With this it should last long the guaranteed life span.
However, if one wants to pull the life span of the battery even longer , then applying 20-80 rule (some book says 40-80) is even better. That way you can stretch even more.
In another analogy, it is like stretching life span of human life by balancing food, sleep and regular exercise
As I understand, only 2.4KWh is usable in 450 which depicts 100% capacity. (even though 450 has 2.7KWh, 0.3KWh battery is not usable and has no connection with the capacity)
In other words i.e. 2.4KWh means 100%, 1.92KWh is 80% .
Oh… Thanks for the info
But i think somewhere in the medium post/forum shreyas mentioned that the usable capacity of the battery was restricted for this purpose…
If it was not restricted on purpose, can you please explain is that a limitation of battery technology?
It’s indeed restricted on purpose. We cap about 5% both at the top and at the bottom. The 0-100% that you see is actually scaled to 0-100% from 5-95%.
While you do not need to charge from 20-80 for improvement, it definitely won’t hurt. The only thing is, the amount of effort to do it is far greater than the gains. Also, the battery life is not impacted by usage (charging and discharging) as much as it is impacted by calendar aging.
@abhishek.balaji2, @Shreyas, it would be really good if you can share some more insight to impact due to calendar aging. I do remember reading some blog about this but I am not able to recall it now.
Battery discharge overnight has been 3-4 km in winter season in comparison to 1 km in summer
have constantly observed from last 1 week
day1: 3 km
day2: 4 km
day3: 2 km
day4: 4 km
day5: 5km
Vehicle is hardly less than 9 months, what could be the reason for discharge rate in-consistency
