On the GST road from Chromepet to Tambaram should be good for new Ather owners from southern tamil Nadu entry to chennai …
Selaiyur, Mahalaksmi Nagar or Gowriwakkam
If u require space in adyar Havmor ice creams do check out.
Need atleast 1 in north chennai
Parrys
Royapuram
Mount road croma as large space
What about Avadi?
If the scooter can be ridden to approx 75 kms at full charge, it will be very useful to have charging points located at a radius of 70kms from the city. This way the rider can ride up to 105 kms at one stretch after stopping at the recharge station for a quick charge. He will also be able to return on the same route with enough charge on the scooter and if he stops at the recharge station for a quick charge , will be able to return to the starting point.
Locations and their approximate distance from the center of Chennai.
[61 km] - SingaPerumal Koil
[60 km]-Chengalpattu
[50 km] Tiruvallur
[45 km] : Gummidipundi
[43 km] Sriperumbudur
[34 km] Vandalur
[29 km] Tambaram
The charging points if placed in the places listed above, will make it possible for riders to use the scooter safely for 70 + 70/2 = 105kms and return 70/2 km stop at a recharging point and ride for 75kms more to reach the starting point. This is possibly the maximum one can ride using one hop, if the recharging point is located at any of the places mentioned below then a single ride can range from 64kms to 105 km onwards with a one-stop point for recharging and also return to the starting point.
Nice suggestion
Hi Abhishek,
suggest to check out the pantaloons and also chennai silks show room. meanwhile i will explore and let you know some other places
Ather should open more grid points soon in Chennai . Only few grid points are active .
North Chennai we need one grid KOLATHUR/molakadai/vyasarpadi/madhavaram
Redhills will be good for grid. It will be easy to go TADA waterfalls/ ponneri/Enmore port
You removed grid in kolathur ( bikes and burger) why try to install one in north chennai kolathur or Perambur. Install 70ft road easy buy
If you are planning for tada falls Mahalakshmi Filling Station No: 465/4, Iyerkandigai Ketnamalli Village, Tamil Nadu 601201 https://maps.app.goo.gl/PtM75qebYpZBztMf7 You can change hear sir
Greetings Abhishek,
Hope you are doing well., Below are some suggestions in chormpet and other locations as well. This are some interesting place where foot fall is large in number and a regular place of visit by people living in and around .
This suggestion are based on large parking areas ,large foot fall , and easy access to technical feasibility with security around the clock.
The Chennai Silks - No 1, Grand Southern Trunk Rd, Lakshman Nagar, Chrompet, Chennai, Tamil Nadu 600044
Nalli Silks - No 202, Rajaji Road, Grand Southern Trunk Rd, Chromepet, Chennai, Tamil Nadu 600044
Super Saravana Stores - Chrompet - No.159, Grand Southern Trunk Rd, Lakshmi Nagar, Chromepet, Chennai, Tamil Nadu 600044
Some other Place if interested
Fantastic Jeyachandran - 1A, Jeyachandran Nagar, Pallikaranai, Chennai, Tamil Nadu 600100
Reason for suggestion : Large foot fall daily base . near or say connect to Chennai IT CORRIDOR, Sholinganallur ,Large parking area for two wheeler. Hang out place for evening with food stalls.
Thank you Regards PRASANNAKUMAR V
Oh yes please Ather, we in south chennai have absolutely nothing here , the closest one is in Alwarpet and I hate to break it to you but it’s completely glitched and for some reason refuses to charge !
Hey please make sure to raise a ticket via the app! Have often found this helpful, atleast when it’s a grid issue.
Hi Abishek. Please install 1 Grid in Parry’s. We have more than 30 Atherians in Parry’s surrounding. Yesterday meet also we mention about North Chennai. Turn your eye to North Chennai😢
I have 450x series 1 . Grid in vadapalani forum mall and ampha skywalk is not working . Its only working for 450 users. Pls change it to new grid
This is interesting I thought all the fast charging stations in ather grid are now 2nd generation.
So still 1st gen stations exist!!!
Dont think there are any 1st gen or 2nd gen charging points. The vehicles charge at different speeds using the same point (thanks to their respective BMS).
@abbas.mech16 do make sure to raise it as a ticket via the Ather app. resolutions to posts on the forum are unlikely to happen.
