Hi sir… I am sure u havent donde your research on the bike… Wen ever there is lode on your motor the battery tends to drain faster…
If your in eco mode if u drive in full speed it will drain your battery becoz you are using the full capacity of the motor in that mode… If ir in eco try to ride it at 20-30 speed, ride 30 - 40 , sports 40-55 iam sure u will find drastic difference in the milage. Plz make sure u dont allow the red haelo to go up. Try to ride in blue. Battery will drain if the vehicle is not shut down completely coz it has a jio 4g sim inside and its connected… So it will drain. U can shut it down to avoid that perticular issue…
I happe your satisfied with the answer
87 to 90KM Range in Sports mode several times.
Ather connect pro is free to all so request you to check ur ride logs after finishing you rides and analyze your ride efficiency, or can share here so that all can understand what is the real problem. my ride efficiency is around 27 to 29 and i get 80 to 90 km range all time.
I just got 74kms on Warp mode with start stop traffic, bad roads, pillion. All of this over a period of a week.
R u taking about projected range ??
hi started using SMART ECO recently and found out when the charge is 100 percent the eco drains quickly even if i reach 40 km/hr speed , but in the last 50 km range the smart eco does not show red indication even if i ride in 50s … can any one share your experience ???
Smart eco tries to maintain under 30Wh/km for every ride and it works best on rides above 10km. Main thing is, maintaining throttle input even during the start. If you accelerate hard from 0-40kmph in eco mode at the start of the ride itself, you’ll be getting red soon than if you do it at the end of a balanced ride. The tip is to maintain same throttle when accelerating from standstill from a traffic light for example.
Please take a look at my ride blog Ride to Thrissur EC where I rode in Smart eco mode for 50km distance, still maintaining 22Wh/km efficiency. This was starting from 94%.
From my view the vehicle range depends on your riding style and pillion. I ride all time in sports mode and i will easily achieve 65-68 where claimed range is 60 for sports mode. It depends on how speed you are riding.put in wrap mode and ride on avg speed of 45-50 you will easily get 60-70
No sir, actual range based on KMs ridden
Hope these help to convince you to think the opposite. I get a range of 100 kms in 1 charge usually in Sports mode. 124.6 Kms on a single charge.
Ather never fails to deliver what they promise. Riding style is the main game…
May I know whats ur body weight bro ? And are you riding in plains or uphills ?
Body weight = 79-80 kgs
City= New Delhi
Number of flyovers crossed ( I actually counted) = 17
I did aggressive regen braking in addition to light hands on throttle and constant speed of 18-20 and sometimes 30-35.
I hv never seen projected kilometre of 100+ kms till date always I see upto 85kms and below 90kms… You people might have experienced alot more with the Ather but unexpectedly I got very minimal mileage till date even on Smart Eco mode riding speed is 25-30kms maintained still at the end of the day I get below 80k mileage and yes air pressure on tyre is all ok with 30-32psi rest I will say riding this EV is a pleasure no issue with it but in rainy days its a big bug as noise starts comming out from rear suspension and wheel don’t know why need to grease few rusty area due to rain water and mud.
ANDROID USER The smart feature is again pathetic doesn’t gets automatically connected when turned the keys on need to navigate to the app and force connect manually and evn the music doesn’t skip or pause just stucks on the 1st song playing when connected and gets freezed even if any calls arrive the caller info doesn’t disappear either even after the call the caller info and call duration keeps on counting and freezes badly and needs the scooter shutdown or keep keys turned off for 7 mints until the last ride info soft resets. Big bug!!
Here is another one for you buddy. This time Sports + WARP. Will share the ride logs of my rides after the last charge.
Same bro from today ride stat no updating
Same here not updating from 5days
Not getting proper milege Ather failed it’s promise I’m getting 70km only, my vehicle is 450x model
But after i posted in forum luckily after 1-2 hrs ride stats started working automatically but doesn’t know why start and end location of ride sometimes seems wrong
I get 90 plus on even on sports with mix slow and fun riding also
