Any specific reason
Why athers structure is for alluminium ? I wanted to know about this ,
Lighter and stronger than another steel body. Since it is an EV, weight matters to range. If steel was used, the EV would be heavy (like Bajaj Chetak which uses steel) and will affect the range available for battery. Aluminum frame is mostly non corrosive as well. Increasing the water resistance.
Thank you…kgeshwaran…
