3rd Topic on the Forum by me.
Just a small blog on the ride taken on 30th June 2022.
Started with 71km range in Smart Eco mode and 87% battery from home to Vytilla, 31km from home.
Ride stat :
The weather was cloudy, but only light drizzle.
After the ride, had 37km estimated range left, as shown in the dashboard. The place was so close to Kochi EC, if needed fast charging, had an option to go to the showroom.
The return journey, decided not to charge the scooter and try to reach home with the range remaining. It started raining on the way back, I had worn rainwear for the same. The ride was more difficult due to rain increasing.
Used only smart eco mode on the way back with around 40-50kmph speed.
Ride stat :
When I reached home, had 3% charge with 2km estimated range. 37km was enough to reach home safely.
Final dashboard:
FYI, had made some small rides before starting this ride. So trip B is from 98% charge.
Entire ride was under 30wh/km efficiency, so got the true range of the scooter. The small rides before are having similar efficiency figures.
This is also a test to see how much time it takes to charge from 3% battery. Started charging at 10.38 AM
Will update the time after it is charged.
60% at 12.52 PM ( 2 hours 14 mins)
81% at 1.45 PM ( 3 hours 7 mins)
100% at 3.16 PM ( 4 hours 38 mins)
