@abhishek.balaji When is the next OTA update scheduled and anything new with updates? Also, earlier it was said that updates are gonna bring features such as TPMS for tires. When will this be rolled out?
TPMS requires additional sensor to be installed in tires. It is an add-on with an optional purchase option. I think it will take time for TPMS to come as it is still in beta stage
What about the range improvement? nobody talks about that
We need regen modes like riding modes. Currently regen is in low level. We can map riding mode with corresponding regen strength. Like eco has most regen, ride mode has a bit less and so on. This would help in increasing range a lot.
Yeah. Ather should increase the level of regen to get more range. Also, it will help to understand if there is an infographic to know how much percentage gained back through regen.
Yes, need both in the dashboard of the scooter and in the app ride statistics
Also the regen should not start after 80% battery drop, it should be there starting from 100%, as sometimes it becomes confusing when trying to slow down using -ve throttle on slopes.
Discovered Hill Assist somewhat on the 450X. While I was my parking slope going upwards, I tried holding the scooter there. I gave just a bit throttle input and the scooter Stood there perfectly. Though when again going upwards, it slipped back then only went ahead. I understand hill assist should hold it well but it did hold it well but slip was there. To verify, I have tried it 3-4 times and it does work. I have also tried it on sloping road once though it had less gradient. For those who are going to try this, please do so on your own risk. Just tried this And it somewhat worked so decided of sharing.
hey according to the manual - CAUTiON " Do not try to hold the scooter at a place using partial acceleration , while on a slant. in all likelihood , it will damage the motor." page 58 of the 450x manual states this so I don’t recommend doing this .
Thanks for the caution. I do not use it but just found that so decided to share. Also what I use is 2-3% of throttle which does not show any speed on the dash but I will remember this. Thank You!
I think what you experienced is a clutch bite point common in ICE, it’s a point where you have acceleration and movement in a locked position without the application of a brake. Commonly in EV, it will be the same but without actual clutching, we give slight acceleration till the vehicle will not rather move nor it will go back but will hold still.
It should be something with the heating. The motor is air-cooled, so might see some off the chart temperatures, maybe?
Has any1 faced issue with internet connectivity on Ather, where the map doesn’t load. Also the sync between bike and app doesn’t happen. It is happening for me currently and I tried doing the shutdown and restart, but that also doesn’t help. Any clue on how to get this resolved?
Try hard reset and move your vehicle at a location where good neteork coverage is present
Hey. Our network provider has just informed us of an outage on their end. We’re waiting for them to let is know once the issue is resolved. This was at 1433. I sent them at 1300.
Sent through twitter.
Oh k, also to let you know, the tower symbol on dashboard beside the bluetooth symbol, that is also not visible.
Ya. I saw that and tweeted and got the reply
Hence, it becomes more important that Ather enables wifi so that we can use hotspot. Duh…!
Yesterday I travelled for 40 km. 4-5 shutdown and 2-3 restarts. Nothing helped.
It either showed 1 point or no signal. Had to use phone throughout.
But, jio phone 4g had good signal throughout.
Last week, had same experience. But, couple of shutdown and restarts and waiting for 2 minutes helped to bring signal back
Really that is what I felt yesterday… a hotspot from my phone Would have helped.
Or at least an option to download maps in storage for the radius will help without internet.
