@austin_carvalho2000 i guess it normal for now ! But an update can fix it. Hope Ather adds this a safety feature !
In that case there should be a manual user trigger for this feature ! If there is some side stand sensor problem then user can turn this feature off and warp !! Zuiiiiii
Customized sound ! If this comes on i know what i need to put for park assist !! Ohh ##* get out the way !!!
Itās better to check the speed and if speed is zero and motor running and stand is down then motor should switch off.
I think ather can take care of this in next update
Could it apply here too?
Iāve actually spoken to people whoāve had accidents on their athers and all of them had to just replace the panels and a few parts and they were good to go. No issues with the frame/ chassis
What will happen in case of major structural damage in accident ? That canāt be covered under warranty for sure. So 450/450x will have to be scraped then ? Since this is aluminum structure which hinders repairability compared to regular steel chassis which is easy to repair or replace.
Warranty never covers accidental damage, that comes under insurance coverage.
If you are such an accident that it breaks or damages the chassis, the vehicle should be junked - irrespective of whether itās an aluminum chassis or tubular frame.
Dear Ather Community,
The use of Aluminium is automobiles is common in high end cars, The Aluminium panels can be repaired and welded provided the manufacturer provides the same to the repairer. If the Chassis of the Vehicle is damaged beyond the economic repairable scope it will be replaced and all the insurance companies do the same. Accidents do happen and does this make anybody to completely resist the usage of vehicle, Driving the vehicle with proper care will eliminate the scope of accidents. Most of the two wheeler accidents happen due to sudden braking and the same can be prevented by proper analysis of the roads. For example, if you happen to see a Dog, or an Autorickshaw or a Child, do remember they will jump in front of you at any time. Make sure that your eyes does not get distracted while driving. If you are using a two-wheeler costing around 1.75 Lakhs, make sure that you use a good helmet which is capable of protecting your head at all time. I would suggest that, everyone wear the helmet first and then unlock the two-wheeler. Drive safe and Care for all the Road Users.
In the case of major accidents it safer to junk vehicle instead of repairs. But what about minor accidentās like when one side of the frame is flattened or broken currently, ather doesnāt even do repainting for panels so what about chassis?
as per design point the main structure support is battery console so rather anything happened for fork neck assembly or rear cradle will be replaceable rear cradle is an aluminum alloy i think so
kindly settle up these are all not an issues its a system doing its job so relax and continue if anything ather will take care we wont leave them if any mfr defects means donāt worry
Itās normal only bro. If u have left the vehicle under the sun for a long time or if u have been riding it for a long time with full brightness on the display, it runs the fan under the display to cool the device. Nothing to worry ur good to go.
